Replace rear axle coolant cartridge
#11
I was told that, when not replaced in time, the excess fluid can end up in the motor and fry it. The tech who replaced my motor explained to me that the cause was the overflow being thrown into the motor, i.e. had it been emptied earlier, the motor would not have failed. I spoke to another tech about this and he stated that too much fluid accumulation in the can is a sign of the engine seals not doing too well and, in my case, that may have been a consequence rather than the cause of engine failure. Inspect and change it often enough, to be sure.
The tech who replaced my motor said the can could be user serviceable. He said it can be reached without removing any of the underbody panels.
#12
after reading this I wanted to make sure I got this done on mine for its 20,000 service (as that's what the manual recommends as well). I was just called and told the master technician on site said it's not necessary and they didn't do it. Should I press the issue or just go with what my service center says?
That said, the tech might have looked at it and saw it was dry - so really no reason to replace the bottle. But you want to know if that's the case.
#13
They will keep saying that it's not necessary and try to Jedi mind trick you until the car is out of warranty. They tried to do that with my 2006 S4 that was blowing oil through one of the pistons. At first they said it was "normal" for the car to be consuming a large amount of oil. I was adding a quart every 1k miles and I knew that what they were saying was bs, so the next step was to DEMAND that they do an oil consumption test. They dragged their feet and kept saying that it wasn't necessary. At that point the car had 92k miles and they were hoping that the power train warranty would run out. I had to contact Audi USA and inform them that the dealership was stonewalling me, and that it had been going on for 6 months. Soon afterwards, the dealership called me, asked me to drop off the car so the engine could be rebuilt, and they gave me an A8 to drive in the mean time. When I came back to get the car they showed me the badly scored piston that was causing the oil leak.
I learned a lesson from that experience, and from now on I immediately take the car to the dealership whenever there is any hint of a problem, and I don't stop bugging them until the car gets fixed. My etron has been having intermittent issues with adaptive light malfunction warnings, and yesterday I got a laser light malfunction warning for the first time. I have already taken the car in once and their solution was to update the software. It didn't solve the problem so I am about to take the car in again. Sure, maybe the issue is because I drive off in the car right after I start it and the software is still loading, but it shouldn't be happening regardless. I am not going to let it go only to have the next potential buyer complain about it and either not want to buy the car, or offer thousands less. It's a minor issue and there isn't actually anything wrong with the adaptive lights, but a prospective buyer will still make a mountain out of the mole hill.
I would make the service tech take a photo of the empty coolant reservoir and show it to me. I assume it's empty because they are saying that it's a non-issue, but I would demand proof. Don't take their word for it.
#14
Thanks all I'm not presently having any issues (aside from the telltale twilight/license plate light error messages), so didn't push back too hard on it, tech wouldn't discuss so didn't get much details other than they inspected it and determined it wasn't necessary, it is noted on the receipt that the work was requested and not performed for all that might be worth. I have an extended warranty so hopefully should be in ok shape if anything ever does go wrong.
#15
mikeru (09-22-2023)
#17
IF the issue with your lights is simply because the car hasn’t had enough time to boot up all of the systems before you engage ‘D’, and your “intermittent” issue would be potentially almost 100% resolved if you did give the car an additional 10 seconds to enable all systems especially during the first start of the day, WTH won’t you give the software that time? Do you enjoy getting pissed off at the car and constantly complaining to the service department? You do realise that a bad firmware download you’ve forced service to perform because of your constant whining could result in an even worse situation? Vehicles today are so computer intensive that to ignore that is at your peril; as you seem to have found out.
#18
Originally Posted by wvu_sam;[url=tel:25847691
25847691[/url]]The only time I get weird errors is if I don't give the software time to load. Not doing so and complaining about errors makes no sense.
It’s in the software development Bible, chapter one, verse two: Thy software shall do what you want of it, not the other way around.
#19
I'm on the other side, the idea that you hit the start button but then still have to wait for some order of operations before actually using the car sounds silly, and I'm surprised so many of you are responding like its ordinary acceptable behavior for the car, how long do you guys have to sit there waiting before you can put it into drive?
#20
edit~ If the car's software throws errors at you when you start to drive right away, that points to an issue with the car's software, not the driver.
