3b flywhhel verses AAN fly wheel?
What do I need to know?
Are the stack heights different?
machining cost on the 3b vs the AAN DMFW?
Clutch availability for RS2 applications?
Thanks
Thanks
You would be wanting a 7A FW as it has the provision for the pilot bearing and the pilot bearing goes in the crank on the 3B(not sure if you can just put the PB in the crank and have it work?). For the 7A FW you would need an upgraded 7A clutch setup I suggest southbend. As far as the stacked height is concerned yes they are different thus the reason for the 7A clutch/pp. The 3B/MC2 FW is the lightest of all the factory I5 FW's. You can have a 7A lighted/balanced by removing material from the rear of the FW.
Former Vendor
3b flywheel is not recommended. Stack height and spline height differences, for starters. Coupled with the lack of pilot bearing provisions. If you're in a pinch you can run it, but it's not really ideal.
There's plenty of lighter aftermarket flywheels with all the proper dimensions.
Former Vendor
No problem some of the common options as follows:
Stock fitment AAN replacement, uses stock AAN style clutch:
http://www.034motorsport.com/product...roducts_id=636
CQ/7A style flywheel, aluminum or steel:
http://www.034motorsport.com/product...roducts_id=285
http://www.034motorsport.com/product...ducts_id=13849
7A style flywheel require 7a clutch kit:
http://www.034motorsport.com/index.p...2445_2491_2496
thewatcher101
08-19-2007 04:27 PM
MiniMan
Audi Original "S" Cars
05-16-2007 06:14 AM
germantoy
03-19-2007 12:48 PM
AndrewsQuattros
12-05-2003 05:51 AM
evilaudi
08-18-2003 08:12 PM
