Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
How much stiffer is a Bilstein Sport Shock / H and R Sport spring setup then stock.
Old 02-22-2007, 04:03 PM
S4orceaudi's Avatar
Default How much stiffer is a Bilstein Sport Shock / H and R Sport spring setup then stock.
Looking to upgrade but don't want an unlivable ride, plus I know lots of you guys run this setup so I thought I would ask. I didn't find what I was looking for with the search.
Old 02-22-2007, 04:04 PM
UrSoccer_mobileĀ®'s Avatar
very stiffer
Old 02-22-2007, 04:07 PM
c4S6's Avatar
In a good way.
Old 02-22-2007, 04:58 PM
Junior Member
TRTW's Avatar
Default I am very happy with my Bilstein HD/H&R Sport combo
The ride is definately tighter and stiffer but not uncomfortably so. And the ride height differance is just perfect for me.
Last year I put a set of Vogtland sport springs and Bilstein sport shocks on a 98 A4 and I felt that ride was too stiff for my tastes..... take that for what it is worth but for sure the setup on my S4 is softer.
Old 02-22-2007, 05:51 PM
S4orceaudi's Avatar
good to hear thank you!
Old 02-22-2007, 08:20 PM
EricAl's Avatar
Default Re: How much stiffer is a Bilstein Sport Shock / H and R Sport spring setup then stock.
I had Bilstein Sports with Eibach springs on my 95 S6. This is a non-tracked car. The ride was very harsh - as if I had 100 psi in the tires. I removed the Bilsteins after about 1500 miles and installed the OE shocks and struts. Ride with OE shocks/struts and the Eibachs is wonderful.
Eric
95 S6 (18 inch Avus, Eibach, SP 9000's, Big Reds, Chip, Digital Boost ga.)
Old 02-22-2007, 09:32 PM
Default This is not the first time i've heard of this setup
but I would think the OE shocks could not control the stiffness of the eibach - which is obviously stiffer than the OE springs.
So you don't bottom out at all?
Old 02-23-2007, 07:15 AM
EricAl's Avatar
Default Re: This is not the first time i've heard of this setup
I THINK(!) the Eibachs are not much stiffer than the OE springs - just lower - and the OE shocks/struts control them adequately. In any case, I do not bottom and the car is very comfortable.
Old 02-23-2007, 08:22 AM
New Member
katit's Avatar
Default Bilsteins designed to match OEM springs
For this exact reason I had my Bilsteins re-valved to match H&R's
Now it's stiff, but good. Balanced. There is no "kick" on rebound.
A4_Maverick
03-03-2006 02:12 PM
RL5sport
02-06-2003 01:25 AM
American S4'n
01-23-2002 11:01 AM
Quick Reply: How much stiffer is a Bilstein Sport Shock / H and R Sport spring setup then stock.
