Is it normal for IAT temps to always be 15+ degrees C above ambient?
Measured with VAG-COM.
Example
While cruising on the freeway after maintaining 75mph for the past 15 minutes.
Ambient External (dash reading) = 29C
IAT via VAG-COM = 50C
RPM = 2700ish
I noticed while the ambient temperature remained constant what I did with the throttle would change the IAT reading. Careful driving would get it as high as 56C while boosting would drop it to the low 40C range.
I ran the test in the FAQ, sensor came up nominal but I still suspect a possible failure which is why im asking.
Thanks for the knowledge!
Example
RPM = 2700ish
I have found that moderate boost does lower IAT, at very mild throttle I believe...
the input air is warmed by the hot intake manifold. At moderate boost it does not have time to warm so the temp is a little lower. Then at high boost the heating from the compression of the air dominates.
What you are seeing is the same thing I see on my car with the TDS-1
After
<center><img src="http://pictureposter.audiworld.com/15624/enginebaydevicelocations.jpg"></center><p><ul><li><a href="https://forums.audiworld.com/s4s6/msgs/150047.phtml">click for info on the IAT</a></li></ul>
I have never not seen full boost when I put my foot to the floor
When running on the highway I will see about 15C above ambient. If the car was run and allowed to sit for 15 minutes the heat will soak into everything and I might see a 40C above ambient temp until I am moving for 5-10 minutes. I do not remember the full boost temp rise at this time but if you need to know I do not trying a few times next time I am out
Re: I have never not seen full boost when I put my foot to the floor
That would help. Im trying to determine if the ECU has a set intake temp where it defaults to base boost.
I keep on loosing full boost when my car warms up
-but-
If you always get full boost, even when hot, means I might be looking at the wrong thing.
-but-
GTA_Driver
11-18-2011 12:24 PM
Mirror|rorriM
13
07-22-2004 01:08 PM
