Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
95 S6 trouble code 2111- engine speed sensor G28
Old Mar 9, 2006 | 05:55 PM
kinderutz's Avatar
Default 95 S6 trouble code 2111- engine speed sensor G28
the car starts,runs and idles.
what's up with the code?
thanks!
Old Mar 9, 2006 | 06:02 PM
VR_Life's Avatar
Guest
Default Have you had any "glitches", sudden/violent deceleration under boost & load
I'm see this fault code even though nothing is wrong with the sensor.
Did you wind up the wastegate spring, or use the high tension 1.9 bar spring ?
Old Mar 9, 2006 | 06:42 PM
kinderutz's Avatar
Default i'm looking at an S6 i'd like to buy and i pulled the codes...2111 found
the car accelerates fine,idles vith very little play,starts fine.....don't know more
big problem?
Old Mar 9, 2006 | 07:11 PM
VR_Life's Avatar
Guest
Default Clear the code, drive it, see if it recurrs. If you want a replacement sensor I have two
I got the codes, replaced the sensors and it made no difference i.e. it seems you can get this code from the ECU and may have nothing to do with the sensor at all.
Old Mar 9, 2006 | 09:19 PM
kinderutz's Avatar
just in case ,how much is a sensor?
Old Mar 9, 2006 | 11:10 PM
VR_Life's Avatar
Guest
Default Well here's the deal - I cannot figure out which is the right one ...
ETKA says :
078905381 (Grey Plug) Timing Sensor$166
078905381A (Black Plug) RPM Sensor<a href="http://www.worldimpex.com/item_detail.html?sku=10373>$160</a>
However when I looked at connector for G28 (the speed sensor) on the harness it was Grey.
When I pulled the old sensors out of my car they were <B>both</B> black 078905381's.
So I'm totally confused . . .
So I bought the part #'s by ETKA and connected them up the way the harness colors indicated.
IMO : These are hall effect devices which are semiconductors with no moving parts and basically should never die, or fail, unless subjected to some physical trauma or Electrostatic Discharge.
I think the thing to do is check the part # of the G28 sensor you have and just order that one.
Or I have two perfectly working 078905381's which I will be happy to let you try for the cost of shipping, if it doesn't work send it back - if it does work send me what you want to pay.
saranaz
Nov 8, 2010 12:58 AM
Ricerboy_408
Mar 23, 2010 07:49 AM
oddsocks
VAG-COM Discussion
Mar 10, 2007 11:48 AM
RMcQ
10
Jul 17, 2003 07:14 AM
