Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Accessing ECU?
Old 04-26-2010, 05:23 AM
s-envy's Avatar
Default Accessing ECU?
Has anyone had success in accessing their ECU without cutting the carpet? If this is possible, I'm sure the process is quite a bit more involved but I'm interested in hearing if anyone has succeeded in this.
I have a 1995 S6.
Thanks,
Old 04-26-2010, 05:29 AM
UrS4boy's Avatar
The carpet is partially cut from the factory. Just cut it. You will never see the difference. Follow info in the links here:
https://www.audiworld.com/forums/sho...php?p=18872782
Old 04-26-2010, 09:09 PM
GoHeels's Avatar
I didnt cut mine. It was a pain to pull it back far enough but I never cut anything.
Old 05-05-2010, 07:32 PM
SCL
SCL's Avatar
I would not want to attempt trying to get at the ECU without cutting the carpet. It's meant to be cut... just make sure to cut it far enough down (with a razor knife), otherwise the carpet will continue to tear as you wrestle to fold it down to get at the ECU. And there are two plastic covers over the ECU that can be a real pain to get re-installed...so having the carpet out of the way is helpful.
AK_TTuner
06-08-2008 06:16 AM
OceanA4.5
11-28-2005 02:31 PM
ludykriz
04-23-2002 11:33 AM
Gunny to you maggot!
06-01-2001 07:41 AM
Quick Reply: Accessing ECU?
