DaveF. what gauge wire should I be looking @ for the coilpack harness?
Can you source teflon coated wire from the aircraft industry? The issue is a compromise between...
wire gauge (the thicker the wire, the less resistance) and the thickness of the harness (the thinner the better). 14 is normally too thick (insulation) 20 is too thin (wire size). This leaves 16 or 18. But 16 with teflon (thinner insulation) coating would be perfect.
You should consider ordering blank pins from Eagleday rather than the pins and pigtails that the dealer (or Kris) can provide.
AudiWorld Expert
Thanks. Today I'm getting the Volvo plugs, going to electronics supply places for the pins
and also I'm gonna look to snag Jetta OxySensor plugs from the wreckers. I'll dismantle those connector pins so that I can replace the wire.
I want to build wire lengths that are one continual length (as per your musings from an ealier thread)
I'll look into the teflon wire, however it might be cost prohibitive.
Otherwise I'll probably settle for 18awg
TTurntable
06-02-2005 06:18 AM
doggy2003
05-20-2005 11:53 AM
hoov
12-04-2003 01:04 PM
T-28-Quattro de VT
03-09-2001 07:18 PM
