DIY VAG-COM interface
It probably makes more sense to buy the whole kit from ross-tech, but if you like to tinker with electronics, then FYI Jeff Noxon's <a href="http://www.planetfall.com/~jeff/obdii/">opendiag</a> circuit works fine on the ur-S cars. I made a few modifications (added LEDs, changed connectors and form factor), but nothing vital.
<img src="http://pictureposter.audiworld.com/66084/sdscn8299.jpg.jpg">
<img src="http://pictureposter.audiworld.com/66084/sdscn8306.jpg.jpg">
<img src="http://pictureposter.audiworld.com/66084/sdscn8308.jpg.jpg">
I couldn't find a place to buy the 2X2 connectors for less than $40 or so, which just seemed like a ripoff, so I made some out of scrap sheet metal, a few bits of scrap plastic, hot glue, and solder, with a fair bit of dremeling involved. In retrospect it would be much easier to just hardwire in another connector (like an RJ-11 jack) instead.
Parts cost for the whole thing is probably less than ten bucks, but it's labor intensive.
give yourself an in-car OBD-2 connector
<img src="http://www.gabrielcaldwell.com/pix/Audi/VAG-COM/2x2.gif">
<img src="http://www.gabrielcaldwell.com/pix/Audi/VAG-COM/DLC_Pinout.gif">
<img src="http://www.gabrielcaldwell.com/pix/Audi/VAG-COM/96_cav.jpg">
Good place is that little useless dent by the diff lock switch.
eh. that's a bulky and expensive pair of connectors for only 4 wires
And I have other plans for that useless dent, which I'll elaborate sometime over the winter when I get it done.
I do think I'll probably add an RJ-11 jack somewhere in the cockpit though.
MikeQuattro
06-09-2008 10:41 AM
RageRacer
03-30-2005 06:07 PM
hadokenny
09-10-2004 05:40 AM
GHart81
9
11-19-2003 09:18 AM
hoTTub
11
05-11-2002 05:24 PM
