e-brake light flickering on and off???
for some reason when i put on my summer tires my e-brake light (!) keeps flickering on and off and stays on for periods of times and then shuts of, does this constantly, and the ebrake isnt even engaged, usually on bumps or so it goes on and of? anyone know what may be the cause some kind of sensor or something?? thanks for the help
Banned
Check your power steering fluid. Classic symptoms of a low Pentosin (power steering fluid,) level.
Weird. My SVX would do this when it got cold out; it was the rubber cap inside the cap of the brake fluid resevoir getting stiff enough not to move correctly. Nice to know that they share a few similar symptoms of the same thing. Since getting my car last Saturday, I've:
1. Spent 10 minutes looking for the gas cap release
2. Could not find the battery
3. Thought my tailgate was broken because I locked it
4. Spent 20 minutes trying to figure out where the fader was
So far I've been pretty confused. :P
New Member
My 2006 audi is doing it now, it the red indicator light flashes on like 5 times and then turns off, mostly on downhill i noticed, did it to me about 5 times today. This doesn't have any relation to the actual brakes though right? I do need to change my breaks...
my problem was the brake level was to low, check the fluid in your resviour, should be the problem maybe if its the same for the newer cars
Boerge
02-07-2009 08:50 AM
Tsle
10
04-13-2004 10:36 AM
I had my brake fluid changed and 2 days later the power steering is noisy when I turn Coincidence???
booker
06-25-2001 06:00 PM
