Finally got around to try to install the S6 3-Spoke steering wheel again...
I got the correct connector to install the German turn signal stalk into my S4. I very carefully wrote down where each wire went and compared the small numbers on the back of each stalk to make sure the wires went where they were supposed to. I got everything installed including the 92 Instrument Cluster and the additional wiring harness (still need to run the two wires to the pass footwell)
When I started the car the wipers came on. I didn't think the wiring for them was different, so I didn't even check the pinout. They only turn off if I have the stalk all the way up. The other big problem that I ran into is the right turnsignal isn't working. The light in the dash and on the front and rear don't light up at all.
Any chance someone can help me out with the wiring diagrams for the headlight and wiper stalks? I ran out of light tonight, but I may have found a broken wire in the headlight switch harness.
Also, anyone know what pin I would have to run 12V to on the German headlight switch to be able to use the parklight function?
Mike Atkisson
Audi Original "S" Cars
04-28-2008 05:01 AM
MC Hammered
01-08-2008 08:27 AM
a4speed
02-10-2005 09:37 PM
If i were to install something in the Audi i wanted to have light up when i turned on the headlights
XcellR8edAudi
06-30-2004 08:37 PM
