Fog lights in our S6's/can we re wire to activate with parking lights only vs. w/headlights?
I need to be able to use the fogs without the headlights in the most extreme visabilities in the winter. I also would consider aftermarket install of some but cant find a good spot to put them. I have seen the fogs on the A6 in the corners low down, but my dealer thinks it would inhibit airflow for the turbo. Is that true?
This may point you in the right direction.
It worked on my 90q.<ul><li><a href="http://20v.org/light.htm#fognohead">http://20v.org/light.htm#fognohead</a</li></ul>
Endoplasmic
09-12-2008 08:56 PM
Paul3.2A4avant
Q7 MK 1 Discussion
01-20-2007 06:30 AM
/\UDI~o~phile
02-16-2005 12:12 PM
Object
11-08-2001 05:04 PM
