FS - Silicone Michelin man hose and Stock IC - no leaks.
I converted from a Tom and Marc FMIC (later the early 034) FMIC to Apikol(the current 034 FMIC)
I thought the quality of the Apikol product was very good when I saw Eric Phillip's FMIC in the fall of 2006.
Yes.
1.) Before, a couple of hard pulls would be the most I could get out of the stock IC during any time but pretty cold weather. Even then, the third pull would be a touch weaker than the first two.
This was with the stock s/w. After MRC Stage 2, I'd get one really good pull, one stock-like pull, and the rest would be uniformly poor.
2.) On really hot days with the OEM IC, I'd get light, transient pinging on moderate to hard accel. Now, I have to get hard on in 2nd gear to get any pinging, and even then, it's only now and then. Again, this is comparing MRC-chipped to MRC-chipped.
3.) The car got Samcos at the same time, so this might not be the FMIC, but overall improvement in the intake system - before the switch, the boost would come on about 2400 and be at full pressure by 2500-2600 RPM. This is with stock WG spring @ +4.5 turns. After the FMIC, the boost felt like it built faster, and it came on 100-150 RPM earlier.
4.) Most of all, I can do pull after pull after pull after pull, and the strength of boost doesn't seem to fall off at all. This I noticed while bedding in my BBK. Ten back-to-back 10-100-10 pulls (mmmm, pad smoke) and the tenth pull felt exactly like the first one. Which was important, since I did this on the public roads, and needed the bed-in session to take as little time as possible.
kiNGMak.:.OEM
04-09-2007 03:49 AM
S4orce2001
04-16-2004 12:22 PM
Samco hoses: Are they for stock IC only, or can they be used on OTC FMIC too? Cause OTC FMIC already
DirtyVegasTT
10-08-2003 04:05 PM
