HELP- How do I get the lower Exhaust to Turbo nut off?
You know the one in the back lower corner next to the engine? I can't get anything in there to get at it. There has to be a trick or tool that I am not using.
Thanks in Advance
Thanks in Advance
Get yourself a 15mm obstruction wrench (half moon) and heat it
<center><img src="http://pictureposter.audiworld.com/52091/wrench.jpg"></center><p>with a MAPP torch and bend it as shown in the picture.
I use a 15 mm box end but I cut it so that the wrench is only 1 inch long.
I put the box on the nut so that the stub points toward the block (horizontal). Stick bar down between the manifold and head and rest it on the stub. Use the bar and a hammer to push down on the stub of the wrench to turn the nut loose.
I don't like bending my tools so what I did
was from Sears I got a set of open ended wrench heads (? not sure what you call them) and they accept a 3/8" socket bar. Put the 15mm open end wrench head on the nut, use a 10" or so bar and a ratchet. You position this between the cylinder head and the exhaust pipes. Works like a champ.
Mark
Mark
Thank For All Of Your Responses...
I went to Sears and bought the obstruction wrench, heated it and bent it to the correct angle. Worked like a charm. I wasted so much on it that it isn't funny.
Thank to all
Thank to all
Always Overcharged
04-08-2007 08:59 PM
imager993
12-09-2006 06:59 PM
Ming rings in Minn
08-05-2005 10:53 AM
obLu
18
04-01-2004 01:50 AM
Big Nodge
09-15-2003 04:29 AM
