How does the boost signal supplied to the ECU boost hose affect the ECU's output?
How else, besides wastegate/N75 operation, does boost feedback affect the ECU? Can it be left disconnected? (Temporarily & plugged of course).
I know what seems to physically happens = wastegate relies upon spring pressure for boost
But if the boost is then controlled by an higher rate spring, w/ the ECU pressure line disconnected doesn't the ECU still correctly compensate A/F mixture using the 02 sensor readings and adjust timing using knock sensor values, coolant temp, oil temp and MAF sensor input?
Seems to me, and I don't have ECU code here in front of me, but it seems to me that the only thing the ECU does w/ boost input is to know whether to modulate it up or down (or limit it) by activating the N75 valve.
The rest of the engine's performance is affected by other inputs.
The only way I can see it playing a role is if the ECU using it like a MAP sensor to detect engine load but the AAN's use a MAF sensor.
Chiming in late but that hose = 70 hp on a stock car. Without it you have a 7A with low compression
On the UrS4s, that hose comes loose at the moisture trap on the firewall and people complain about no boost, no power. Two minutes (okay, five, you need to cut off the old OE clamp) and the smallest gear clamp you have = 70 hp. Otherwise, the only boost you get is that from the wastegate spring, i.e. about 6 psi (gauge) (stock spring).
If you want to disable the boost for a 'valet' mode, disconnect the WGFV.
