Just received my Coil "kit" from EFIexpress
WOW! A very high quality setup. Wiring and connectors are OEM quality. Wire looms OEM Quality. Coils are firmly mounted.
Marc, change the name from "kit" (implies some assembly required) to "system" (showing complete assembly).
As I received it last night, and it is snowing (who forgot to remind mother nature to look at the calendar), and the garage is full of Fiats, I will install tomorrow.
Top notch part from oustanding vendor.
--Kevin
--Kevin
HOLY CARP! After your ignition starts to break down, you forget what you car is supposed to run like.
Installed today. Took exactly 30 min.
WOW. The rabid pit bull is back!
Thanks Marc
Thanks Marc
Looks like a great setup.
I have one question though...do you have any plans of sourcing wires that will allow the coil cover to be put back on? I'm running the Apikol harness and 1.8t coils right now, but if a solution like this was available that allowed for the cover to go back on, I could be swayed.
With the D585 conversion spark plug cables run from the coils, and can be run under the
stock coil cover. Here is a pic of my conversion before the coil cover gets installed.
The stock cover definitely fits over after removing the stock coils. I just dont run it on my s6 because I use it to test the kits before I ship, and I got tired of removing it Juan Million times a week
