Location of Autocheck Module
So lately my autocheck module is saying the brake pads are out and the head lights go in and out intermittently. It drives me crazy. Where is the module located? I have done the headlight control module labatomy and hardwired the brake pad connectors and still no help so I'm thinking it must be an issue at the autocheck module. Can the entire module be disabled or does anyone have a pinout so I can hardwire the brake pads and front lights at the module?
Thanks!
Preston
Thanks!
Preston
It's in the cluster. The PCB closer to the front of the car.
It's probably a cracked solder joint if you have an S4. The earlier PCBs are phenolic and they flex. Take it apart and resolder all of the through hole leads you have the patience for, focusing on the connectors.
<a href="https://forums.audiworld.com/s4s6/msgs/65956.phtml">https://forums.audiworld.com/s4s6/msgs/65956.phtml</a>
CincyQuattro
11-19-2007 10:00 AM
t0adman2.8
12v V6 Discussion
04-21-2007 12:25 PM
BluDemon
09-08-2005 06:39 PM
