Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
oil line in/out?
Old 02-21-2007, 08:44 PM
New Member
quattro_rocks's Avatar
Default oil line in/out?
Just to double check, k26/gt3071 turbo has a check valve for the oil, is that the oil in?
And what are the thread connections?
Old 02-21-2007, 08:47 PM
a4kquattro's Avatar
Default restrictor goes on the inlet (the small one on top).
not sure on the threads but its metric and not pipe thread like the thrust bearing turbos... M10x1.5 maybe?
The oil drain is a two bolt flange affair.
Old 02-21-2007, 08:54 PM
New Member
Default Re: restrictor goes on the inlet (the small one on top).
okay good, so that line has to be replaced though.
will the stock oil line work?
As you can tell i haven't started taking things apart yet.
Old 02-22-2007, 05:40 AM
a4kquattro's Avatar
Default you can't re-use any of your oil or water lines
The only line I sort of re-used was the water line that runs behind the timing belt cover. I cut the steel pipe and slipped stainless steel braided hose over the cut end and attached a custom 90 degree fitting onto the turbo.
Old 02-22-2007, 05:08 PM
New Member
thanks guy...that clears things up...appreciated
SpanOil
11
07-05-2006 07:07 AM
onebrokenneck
10-16-2005 10:51 AM
D Spin
05-23-2005 07:58 PM
Immigrant
09-26-2004 05:54 PM
Žob
26
06-03-2001 03:06 PM
Quick Reply: oil line in/out?
