Pic request
Pic request
Anyone running Eibachs w/ 17" rims on 235/45/17 AND ECS perch spacers in the rear? Want to see the 13mm and 20mm.
I'm leaning towards the 20mm ones....
TIA.
TIA.
Eibach Pro Kit+Bilstein Sports+ECS spacers(10 or 13mm, don't remember exactly)
17x8 wheels with 255/40-17 tires......FAT!
<img src="http://pictureposter.audiworld.com/92966/img_4558s.jpg">
<img src="http://pictureposter.audiworld.com/92966/img_4550.jpg">
I don't have a pic, but had the same exact combination you're requesting
My sig pic is before the spacers w/ Eibach and 235/45/17. I added the 13mm spacers and the rear still looks slightly lower than the front, but I think the 20mm would be too high. I could get a pic and post it tonight, but I now have 245/40 tires that are shorter.
For as cheap as the spacers are and as easy as they are to install, order a set of each and see which ones you like better. You could probably sell the set you don't use and recoup most of the cost.
from what I heard, the 20mm spacers will look almost stock
so I went with the 13mm. If I have to remove the rear shocks for any reason, they'll be coming out cause IMO it's still a little too high.
oh, this is on an Avant w/H&R sports and Bilstein sports.
Harsany
S6 (C7 Platform) Discussion
04-26-2013 05:26 AM
WallyTT
10-07-2004 09:02 AM
RidgeS4
04-10-2002 07:43 AM
