Quick Question
Usually it requires a bit of dyno time with A/F and EGT (if you can) logging.
You'd then forward the graphs to the person whom would code and burn you the chip.
You can also by chips that someone like Mihnea Cotet have pre-coded (based on the values of other cars with similar modifcations) that *should* well work with the setup on your car.
These cars cannot be "reflashed" like a newer 1.8t VW.They require a new chip set (two chips) and...
probably (in many cases) a 3.0 bar pressure transducer or equivalent (VMAP).
