tips or hints for easy outer cv replacement?
should i unbolt it from the tranny and just pull it out? or should i free the ball joint and remove the joint from the axle?
skolnick, you usually have good methods...
just free the ball joint
pull the axle out of the hub. I think last time i did it, i re-inserted the bolt that holds the axle in, and srewed it down all the way, the cv will pop off. Make sure you replace the clip that holds the cv on.
Also, you will need a really long bar to get the ball joint off w/o tearing the boot. The one i use is ~5feet long.
Personally I would remove the axle bolt, unbolt the axle from the trans and work on it on a bench.
No need to pop the ball joint to get it out. If this is the driver's side, I can hook you up with a good axle so you don't have to mess with CV joint grease.
Re: tips or hints for easy outer cv replacement?
Remove the entire axle and change the CV joint on the bench. The additional work of unbolting the axle from the transaxle is minor compared to the extra effort of changing the CV joint with it still attached to the car.
I know some do change it with it still attached but I suspect these are people who are very experienced and for whom even minor additional time is a factor.
Be sure you have a triple-square driver and a long bolt for pressing the old cv joint off the axle.
Eric
Eric
quadrinary
05-06-2005 06:29 PM
RussB
15
03-08-2003 10:08 AM
computrtutr
12-10-2002 09:26 AM
