Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
What does this plug into?
Old 06-13-2003, 04:39 PM
Mike Desi's Avatar
Default What does this plug into?
<center><img src="http://pictureposter.audiworld.com/34876/relays.jpg"></center><p>Took a look at the relays behind the passenger side kick panel and noticed a plug just dangling there. It looks as though it was plugged into something, but maybe the PO or grease monkey unplugged it. It's not the clearest picture but its the purple/pink plug in the center of the picture. Where does it go?
Old 06-13-2003, 06:47 PM
New Member
SilverUrS6's Avatar
Default Re: What does this plug into?
it looks like its the top speed limiter... unplugged to deactivate it... only way to tell would be to take her up to 130+mph - if you get there its the speed limiter...
http://www.urs4.com/technical/engine/topspeed/topspeed.html
Old 06-13-2003, 08:05 PM
Mike Desi's Avatar
I don't think it's that plug. The size and configuration is different. My plug is a straight, small, four pin [----] plug that has wires going only to the two center pins.
Old 06-13-2003, 10:34 PM
UrS4boy's Avatar
Default Whatever it is, it isn't the speed limiter. If you want to know where that is, go to...
http://www.intendedacceleration.com/html/tip_9.html
Lots of other good stuff there too. Ned Ritchie does good chips and can to custom maps and turbos and has his own exhaust manifold design.
Dave F.<ul><li><a href="http://www.intendedacceleration.com/html/tip_9.html">http://www.intendedacceleration.com/html/tip_9.html</a</li></ul>
Old 06-14-2003, 09:06 AM
Bangetek's Avatar
My car has the same plug behind the passenger side kick panel .... its probably just a feature we dont have.
I have a exploded wiring diagram for the UrS tell me the color codes of the wires leading to the plug and i can try to find it (im too lazy to go look at my own car)
Old 06-16-2003, 12:21 AM
Junior Member
Mihnea's Avatar
Default Re: Whatever it is, it isn't the speed limiter. If you want to know where that is, go to...
Agreed Ned has his own manifold (which is still an RS2 EM copy whatever you guys can say) but I can assure you he does nothing custom, and especially no custom maps. All he does is burn chips and sell them but he can't even tell you how much advance his chips are running. Stop thinking Ned is God, Ned ISN'T GOD!!!!!!!!!!!
Mihnea :-p
Old 06-16-2003, 05:45 AM
UrS4boy's Avatar
I stand corrected, Mihnea is apparently GOD. (At least , in his opinion).
Old 06-16-2003, 01:22 PM
Junior Member
Mihnea's Avatar
Default Re: I stand corrected, Mihnea is apparently GOD. (At least , in his opinion).
Sorry mate, I'm not God and I've never pretended I was, but I certainly know more about Motronic programming than most people who think they are tuners in the US, and I'm saying that with no false modesty, simply because I know how much I've invested in my knowledge and where it comes from. If you don't believe it, it won't change my life, I just know what I know, and some people here are also starting to be aware of that.
No offense taken anyway,
Mihnea
Old 06-16-2003, 10:26 PM
UrS4boy's Avatar
Default The thing was I never said Ned was a God, just that he does have 'custom' programs to...
fit the situation, i.e. the particular set of turbo, cams, injectors, EM, etc. that you happen to want to work. However, I will take issue on your statement that the EM is a clone of the RS2 manifold. It is not. It is likely better, i.e. closer to a header than the RS2 manifold. Ned also 'arranged' hybrid turbo's before many others caught on to this possibility. So, on that basis, I guess I will say, Ned is somewhat of a "God", at least in the North American Audi sense. You can be a "god" too, in the Begium/European/cross the ocean to North American sense, if you want. (I know no one who runs your software so I can not make a judgement)
Dave F.
caster
06-24-2004 12:07 PM
Kllrbee
08-22-2003 03:39 PM
delsauce
03-19-2002 02:05 AM
Quick Reply: What does this plug into?
