Where is the 2x2 Connector for the Airbag?
Says it is behind the climate control unit...and I have found what is labeled the Airbag Sensor unit..but NO 2x2 connectors to reset my light...man my hands are torn up now from reaching back in the mess of wires.<ul><li><a href="http://gallery.s-cars.org/airbaglightfix">http://gallery.s-cars.org/airbaglightfix</a</li></ul>
I'm not sure all the cars had a 2X2 connector by the airbag control module...
There's one in my early (no strut bar) 92, but I've had the consoles completely out on pretty much every other year S-car and never saw them before. Try resetting via the 2X2 connectors in the relay panel under the hood instead.
If you want to do serious spelunking in there, you're much better off to pull both consoles- they're not too bad to pull, and once the upper console is out you can get at everything easily.
NW Avant
VAG-COM Discussion
08-28-2003 04:42 PM
