Will these wheels fit a 93 UrS4?
The rims are OZ Superleggera 18x9 with a 35 MM offset, Also if they do fit what would be the best tire size?
The car has the H&R springs with Bilstein Suspension and the Porsche Big Red brakes.
Stock wheels are 16x8 ET40. Use the linked calculator to discover more.
18mm is a lot.<ul><li><a href="http://marksink.com/tire_wheel_offset/offset.html">http://marksink.com/tire_wheel_offset/offset.html</a</li></ul>
I think it MIGHT fit, but that's really wide. You would likely want some sort of rack stop.
So that you won't rub like mad when you turn the wheel too far over.
I would look for 18x8 SL's personally, 9" wide is just not needed on our cars.
nemisis633
07-06-2003 05:40 AM
