Does the steering need to be recalibrated by dealer after alignment?
I got new wheels installed so I went to get my alignment done. The Total Toe and Steer Ahead are dead center but my steering wheel is angled slightly to the right. This happened from two different well known alignment shops. The odd thing is, when I got my suspension installed they did alignment at the same time and the steering was straight. They are a well known mod shop so not sure if it's something that needs to be done with ODIS or what not?
It's part of any alignment and if they forgot to center the wheel they messed up
My car come with 4 wheel steering though.
ODIS:
– Select and start Diagnosis mode.
– Select Test plan tab.
– Choose Select own test and select following options one
after the other:
♦ Systems with diagnostic capability
♦ 0016 - Steering column electronics control unit J527
♦ 0016 - Steering column electronics control unit, functions
♦ 0016 - Calibration of steering angle sender G85
– Start selected program and follow instructions shown on dis‐
play of vehicle diagnostic tester.
hcuorg (05-19-2024)
Yes, this can be done through ODIS yourself. I had my wheel alignment done by a third party company and my steering wheel was pointing a little to the side. I completed the calibration procedure at home and the car began to drive perfectly straight. And the steering wheel went to zero.
ODIS:
after the other:
ODIS:
after the other:
uTTdriver
05-25-2004 08:26 AM
