Audi Q8 Discussion forums for the Audi Q8 SUVs
FAILURE TO START
Old Aug 5, 2022 | 07:04 AM
summersrl3's Avatar
Default FAILURE TO START
having an issue usually when I first get into car in the morning. Doors closed, trunk closed, got the key in hand. Press start, and NOTHING. all accessories come on but engine will not start. ONLY when I open the door, and then close again will the car start! Am I missing something? This happens pretty much every morning. Or after car has sat for at least 5-6 hours.
Old Aug 5, 2022 | 07:22 AM
LEC84's Avatar
Weird, I have a 2020sq8 and this just happened to me for the first time last week. I tried pressing start about 4 times and then it finally started. We were up at the cabin so car hadn’t been started in about 4 days prior to this incident.
Old Aug 5, 2022 | 10:16 AM
avned's Avatar
This sounds like a similar issue I had with my C7 S6. It was a fuel pump failure that rectified the problem.
My first 500 miles of owning my RSQ8 I was getting CEL on fuel pump sensors. They have since replaced it. I imagine it would have had a similar issue if I did not get a CEL.
Old Aug 5, 2022 | 11:18 AM
HDCL's Avatar
I have noticed this sometimes if I don't press REAL hard on the brake pedal, the MMI will just start up, but not the engine. Pressing harder on the brake fixes it - there is no actual feedback, the pedal doesn't go lower, just more pressure on it
Old Aug 6, 2022 | 10:35 AM
MarkIndy's Avatar
I encountered this 2 times in my 2 years of ownership. Both times I pressed a little harder on the brake and she fired right up. You have to push the brake until it stops then, push a wee bit harder.
Old Aug 6, 2022 | 04:36 PM
summersrl3's Avatar
Thank you so much. Some of the other reply’s were starting to worry me. Got in and pressed harder on brake, started right up!
Old Aug 8, 2022 | 02:24 AM
Michael99's Avatar
Top Answer: 1
This same issue started for me about two weeks ago on my 2020 Q8. I can't imagine I'm pressing on the brake any differently than I have for the past two years. Seems strange that it is suddenly occurring for several people. My car has not been serviced recently, so it can't be due to a software modification. Eventually the starter engages after pushing the start button a few times. Maybe there is a sensor on the brake pedal that wears out over time and pushing the brake pedal harder allows it to function.
Old Aug 8, 2022 | 05:50 AM
BOASTY's Avatar
I have experienced this same no-start issue. 2020 SQ7. Probably happened 2 separate times in the last 6 months. Very frustrating. For me, I'm pretty sure that brake pedal pressure is not the issue given how hard I was pushing with no success. This is why I hate push button starts. Makes me miss my Cayenne key start so much more. And while I'm at it, I also miss the mechanical gear selector as well. "Busting a u-turn" is just not possible given how sluggish the electronic gear selector is.
Old Aug 8, 2022 | 07:55 AM
jcitriniti's Avatar
I have also had the rare occurrence of the engine not starting even though the MMI fires up. I also believe it was rectified by pressing a little harder on the brake pedal but have not confirmed that was the real fix.
mikemcguffin@msn.com
New Member Welcome Area
Aug 25, 2024 03:46 PM
andre807
1.8T Discussion
Dec 6, 2017 05:36 AM
prestonian
Audi Original "S" Cars
Jun 4, 2007 10:11 AM
Praetorian
Jun 30, 2006 06:20 AM
LIRS6
13
Oct 6, 2005 06:52 AM
