Audi R8 Discussion forum for the Audi R8 and its variants
Ipod or SD card interface
Old Dec 14, 2007 | 09:00 AM
R8er's Avatar
New Member
Default Ipod or SD card interface
I just took deliver of my R8 two weeks ago...what an absolutely awesome car! The only stag I have encountered thus far is, I would like to use my Ipod (or download Itunes music to SD card) to play in MP3/SD card ports in the R8. Problem is, the SD card port does not read Itunes music that I have saved to SD card (I guess due to different formats). Does anyone have a simply fix/solution for this issue. Please advise.
Old Dec 14, 2007 | 11:17 AM
DukeLeto's Avatar
Default Simple solution...
...don't use iPods
T.
Old Dec 15, 2007 | 04:55 AM
justhacking's Avatar
Default in short, no
the best solution is install an iPod interface but you will probably lose you changer. Take a look at www.dension.com
Old Dec 15, 2007 | 10:00 AM
liquidretro's Avatar
Default Re: Simple solution...
I am not an R8 Owner or really don't have any knowledge of what format it will play but I am assuming that it will play MP3's If your buying your music on iTunes or if your ripping it iTunes in default format that will be in .aac which is not as common as MP3. The purchased songs will also have DRM on them. You can get around this on windows with a program called myfairtunes. Google it and it can eliminate the DRM on those songs. This is not legal but it works wonderfully. As for the songs you have ripped. I recommend ripping them again as an MP3 or converting your .aac files to a .mp3. I recommend 192kb/s or higher. PM me if you have questions I don't come around the R8 section much.
Old Dec 15, 2007 | 09:31 PM
GR8 Ghost's Avatar
Default I put an ICE ipod Integration kit in mine. Powers the iPhone and plays music.
The only thing is the MMI doesn't display song titles, you have to use the ipod for that.
Old Dec 18, 2007 | 07:05 PM
PeterH's Avatar
Default you just need to convert the itunes format to a standard MP3 format and they will play
Along with all song titles, etc on the head unit.
DirtyVegasTT
Jun 1, 2016 04:24 AM
wonb07q7
Q7 MK 1 Discussion
Nov 10, 2007 04:15 AM
Joey T
Oct 18, 2006 05:02 AM
2000s4biturbo::Uli
Feb 13, 2005 09:06 AM
