Is this "noise reduction silencer" worth getting?
AudiWorld Expert
I've got a little bit of audible alternator interference. Would it be worth it to install this Monster Calbe product?
<img src="http://www.thegoodguys.com/GetImage.asp?table=inv&field=image1&keyname=invky& keyvalue=250194"><ul><li><a href="http://www.thegoodguys.com/adtemplate.asp?invky=250194">http://www.thegoodguys.com/adtemplate.asp?invky=250194</a</li></ul>
I know some here will disagree with me here, but I think you're better off
identifying the source of the noise (e.g. bad ground, proximity of power/signal, etc.) than this sort of bad-aid solution.
Of course, if all else fails go for it.
Re: Is this "noise reduction silencer" worth getting?
Hi,
You don't need this...
Take the time and find different grounds mounts for your amp and deck, this is whats causing your audible alternator interference.
Try it out first.
Try it out first.
EasTTcoasTT
01-15-2004 12:35 PM
Bobby Kinstle
18
08-28-2001 09:24 AM
