Anyone have wiring diagram for a Symphony stereo?
Old Jun 3, 2006 | 03:46 PM
velo's Avatar
Default Anyone have wiring diagram for a Symphony stereo?
Trying to find a switched pwr source and the sticker on the unit doesnt really say much...
Old Jun 3, 2006 | 03:53 PM
SouthboroAudiGuy's Avatar
Default There's a switched power tap underneath the dash
The link I provide below points to a post that has a picture of this and includes directions on how to get at the place where you'll find switched, unswitched, and ground power taps.<ul><li><a href="https://forums.audiworld.com/a6/msgs/608511.phtml">Lots of info you don't need, but the info you do is in there.</a></li></ul>
Old Jun 3, 2006 | 11:20 PM
velo's Avatar
Default So looking at Part 4 of that link
<center><img src="http://img.photobucket.com/albums/v739/hliu55/DVD/DVD53.jpg"></center><p>It states this with the pic:
I then disconnected the battery, and made the connections under the dash.
Red = Switched power to 75X
Black = Ground to main ground on left sidewall
Yellow = Battery to 30
There are lots of red, black and yellow wires...which ones? Also, does this apply to a B5 A4?
Old Jun 4, 2006 | 12:50 AM
MacSub's Avatar
Default Switched power is on the ISO power block that plugs into the HU
On the B5 its definately there, referred to as "S-Kont" on the diagram (3rd one along from the brown earth wire), but with newer models they use the K bus, which is why you then need to source it under the dash in that link.
Old Jun 4, 2006 | 03:59 AM
Default Don't know if this applies to B5 A4, but I would guess there's something similar in the same spot.
The key thing to note is that post "75X" is switched power. Ground is easy -- pick a bolt attached to the body. You can see one toward the left of the photo.
Old Jun 4, 2006 | 04:43 PM
velo's Avatar
I have a B5 so not sure if are saying I can use the "S-Kont" or need to go under the dash
Old Jun 4, 2006 | 04:44 PM
velo's Avatar
Right, but in that pic, which red wire is he referring to? There are tons...
Old Jun 4, 2006 | 05:17 PM
Default Doesn't matter. At issue is which red wire do YOU want to connect..
Connect it to post 75X for switched power.
Old Jun 4, 2006 | 11:29 PM
velo's Avatar
Ah, now I see what 75X is...
Old Jun 4, 2006 | 11:35 PM
MacSub's Avatar
Use the S Kont on the connector, this gives you proper ignition on i.e. switches off with keys out
LakeTahoeQuattro
Apr 24, 2025 06:21 AM
dnsrunner
Jun 2, 2009 04:21 PM
spiralsmurf
Audi Original "S" Cars
Aug 29, 2007 04:50 PM
allroadoz
Apr 24, 2006 06:04 AM
pdxnative2002
Audi allroad
11
Oct 28, 2004 07:00 AM
