Help/Advice needed on adding another amp
I already have a fuse next to my battery for my current amp. Can I just up rate the current fuse and hook up my new amp to the same one? or should i get another fuse for this amp?
If I use the same fuse, how should I split the wires to both my amps? Any other advice for a total noob?
Thanks
also, hopefully you know how to run new speaker wire to wherever you're going, and you also know how to get another set of RCA's back and forth from the head unit.
I think my power wire is thick enough, but i'll for def double check that. Are there any places that sell everything I need to install an amp? Do you think best buy or fry's sell them, if so, are they bad quality?
Also, I'm thinking of installing rear speakers as well. MB quarts install in my car without any modifications, but should I apply dynamat to the parts that touch my car and to the areas behind it? Or is that just a waste of money and dynamat.
Thanks a lot, I'm still new to this, so bear with me
As far as distro blocks go, pick one. doesn't really matter much. And no, the remote wire doesn't connect to the power distro block, however you can have a separate block just for the remote if you wanted it. The problem is the remote wire will carry current only sometimes, while the power wire carries a current all of the time.
In terms of dynamatting your car, a little isn't gonna do a darn thing for you, unless you're gonna use it to prevent rattling between two objects that touch each other. Dynamat is usually applied to the bare body of the car, and often times in multiple layers (read: "expensive and heavy").
bottom line- if you don't know what you're doing, either get the help of someone who does, or just take it to a shop. The power wire has a lot of current flowing through it, and one bad move might have a lot of bad consequences...
If you need an amp kit, go on ebay. search for "amp kit new" and you'll be amazed. It's *way* cheaper than buying everything individually. 17 ft. of power wire from my local shop was $35. my amp kit from ebay was $28, and is working great. it's not a PG amp kit, but hey, there's always room for improvement. ;-P
Good luck.
READ THE MANUALS FOR THE LOAD SPECS!!!! Add them up and get the closest fuse to it. If you can't get exact then ROUND DOWN. You don't want to have a fuse higher than what the maximum draw of both amps is because that = fried amps.
The rest is purely personal preference, but you will probably want to run at least 1 distro block for your power. You can run separate grounds, or you can get another distro for the grounds. Purely up to you. Just make sure that when you fuse the lines in the power distro, they're the max load of the amps or less than that...again or cooked amps...
IMHO I like 1 power distro and separate grounds...but that's just me...good luck!!
Best buy is good for cables and whatnot. Get the best RCA's you can get so you dont' have line noise...go with monster cable for power, ground, rem. lead, etc...also phoenix gold is very good as well.
MB Quarts = awesome speakers. good choice. personally I install them..crank them up...if stuff vibrates..rip em out...dynamat a bit...make sure the install is clean..then you're good to go. get dynamat xtreme btw..don't waste your money on ANY other dynamat...the rest suck...
