Little help: Subwoofer wiring question
Hey guys,
can anybody tell me the best way to hook up a Kicker Soloberic 12" 2 OHM Sub to a Kenwood KAC-9104D. This is for a buddy of mine...
specs on that amp...
Class D Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 500 watts x 1 chan.
2 ohms: 900 watts x 1 chan.
1 ohm: >900 watts x 1 chan.
Max power output: 1800 watts x 1 chan.
MOSFET power supply
LED power indicator
Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
Stackable operation capable
Phase inverter (0°,180°)
Speaker-level inputs with signal sensing for automatic turn-on)
Preamp RCA outputs
Short circuit, DC offset, overload, and thermal protection circuitry
Aluminum die cast heat sink
Built-in cooling fan
Gold-plated RCA level inputs
Gold-plated screw terminals
Variable low-pass filter (50-200 Hz, 24 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 5-200 Hz
Dimensions: 13-3/4"L x 2-5/16"H x 9-3/8"D
4-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
1-year SonicElectronix.com warranty
RMS Power Rating:
MOSFET power supply
LED power indicator
Preamp RCA outputs
SVC would be pretty simple to figure out dontcha think?
Connect the red & red with dot to the amp's + speaker output.
Connect the black & black with dot to the amp's - speaker output.
If its a dual 2ohm, this will put you at 1ohm at the amp.
If its a dual 4ohm, this will put you at 2ohm at the amp.
The amp has two speaker connections, but it is still a mono channel amp, so you can use either or both connectors. Basically both + terminals & both - terminals are connected together inside the amp.
The reason there are two is so you can run multiple speaker wires to the amp without having to cram them all into one terminal.
TRY THIS LINK THIS SHOULD DO IT FOR YOU I ALSO MAILED IT TO YOU AS WELL IF YOU NEED ANY OTHER QUESTIONS ANSWERED PLEASE ASK IAM AN INSTALLER FOR ABOUT 20+ YEARS
http://a248.e.akamai.net/pix.crutchf...2-ohm_mono.jpg
Slightly off-topic, but I am installing this same amp in my s5, but can't find a 12v switched lead in the trunk to use. The amp is supposed ot turn on automatically when you use the speaker-level inputs, but it's not working for me. Anyone have any thoughts?
ben gt/cs
16
05-27-2003 08:10 AM
ben gt/cs
02-04-2003 05:36 AM
CMC
01-14-2003 09:37 PM
computrtutr
12-07-2002 08:08 AM
Ray Khan
13
08-06-2002 04:12 AM
