Need quick help with AUDIO...... PLEASE
I'm hooking up an FM modulator. It will be placed behind my stock deck. For a power source, all I can find is some constant 12v+ going into the radio. The instuctions say to wiring the power to the FM modulator from an accessory 12+ (hot wire only when key is in accessory position). Do you think it would be ok if I hooked up the modulator to a constant 12v+ source? Would that cause damage over time? If so, could you recomend a access source that is behind the stock radio? Need this ASAP please. thank you.
Re: Need quick help with AUDIO...... PLEASE
The purpose of hooking it up to the ACC is so that the unit turns off when the car is off. I fyou connect it to the +12V then it will always be on even when the car is off. I don't know how much current is drawn from a modulator because I've never used one but if it's not a negligible amount, you could drain your battery. Almost like leaving your lights on all the time but not quite as drastic.
starting ...
08-25-2004 09:38 PM
