speaker problems, please help...
Old May 1, 2004 | 12:13 PM
2000SantorinS4's Avatar
New Member
Default speaker problems, please help...
there is a buzzing sound coming from my pass. side front speaker. The sound comes and goes when I hit bumps. At first I thought the speaker was blown, could it just be a loose wire? anyone experience this? How could i fix it?
Old May 1, 2004 | 02:07 PM
MacSub's Avatar
Default Re: speaker problems, please help...
Could be a couple of things, but wiring would be the first place to look. The door card is an easy 2 minute job to remove, so check there's nothing obviously wrong with the connections to both main driver and tweeter. With the hifi on jiggle the door card around to see if you can make it buzz.
If this looks ok and you can't replicate the fault you'll need to pull the HU out, check the wiring. If you still can't see anything wrong, try temporarily by passing the Audi speaker wiring and go for a drive. If this sorts it out then you'll need to run a new cable. If it doesn't then it's either a faulty speaker or HU. Switch the speaker wiring over at the HU and see if the fault swaps side. If it does then it's the HU, if it doesn't then its a faulty speaker.
TheRealBooker
Nov 14, 2018 06:41 PM
cpbetts
Jun 7, 2004 01:11 PM
alvinaudi
Oct 8, 2003 07:02 AM
tgray
Oct 21, 2002 07:36 AM
ScottKalmus
Sep 25, 2001 02:29 PM
