New Product: Turtle Wax Hybrid Solutions Pro Graphene Flex Wax Spray
Brand new product- says that it will last 1-2 years. I will re-coat next summer.
True graphene and not graphine oxide as in most of the other products on the market.
Easiest product that I've ever used and pretty idiot-proof. If excess product used- it will streak/high-spot- easily corrected with a damp microfiber towel.
Very happy with the results.
I've seen great videos on this stuff. I plan to use it. What was your process BEFORE applying it? Did you wash, ironx, clay bar, polish, and then apply? Or did you just apply and call it good?
Definitely full paint prep is the key.
Full 3 stage paint correction prior to application.
I used the TW Hybrid Solutions Ceramic Spray on my A4, and have been very happy with it, so far, in terms of water beading. I don't have any expectation that it's good for a year - I'll probably give it another go in a couple of weeks. As far as protection from chips - I do notice that I've picked up 2 small chips on the hood and front fascia, so not great on that front, although I don't believe that anything really would be.
Process:
I applied this in mid December, and it is still holding up well now at the end of March.
Process:
- Basic wash/rinse using Meguiars Gold wash
- Decontaminated using CarPro Iron-X
- Clay bar
- Polished using Meguiars Ultimate polish
- Isopropyl Alcohol rubdown
- 2 Coats of Turtle Wax Hybrid Solutions Ceramic spray (let cure 24 hours between coats)
3 month update: after a wash with Ethos Defy and Elite Finish Detailing WashMist.
Process:
Process:
- Clay bar
I generally wash it as needed using Ammo Frothe. The past two washes, I was in a hurry to just get the pollen off, and used only the soap and rinse at the local car wash bay. I've been following up all washes with a quick wipe down using Meguiars Ultimate Quik Detailer.
The water still glides right off, and shine is just as it was after initial application of the Turtle Wax spray.
OldSkewS4
Auto Detailing Discussion
9
03-02-2008 01:27 PM
barrem23
19
11-18-2003 12:53 PM
looey
08-09-2001 05:00 PM
