Traffic Paint
Traffic Paint
Hey Guys,
The Goo Gone proved to be worthless. In addition to the high pressure wash at a local station.
Is it safe to use a higher PSI on the wheel wells? I would like to remove the residual after 6 months.
Cheers.
Cheers.
Probably going to have to take your tires and wheel well liners off to do a proper job. But yes, a higher psi pressure washer is fine. Just don't use the jet spray, you'll cut right through those liners, lol...
Cheers.
I would use the cleaner tip if I were trying to remove what you have described. 3500psi is plenty powerful enough to get the job done. Honestly, you probably could get it done with a 2000-2500psi pressure washer.
There are pressure washer wands that are all in one adjustable rotatation heads with a single tip. But, honestly they don't do a great job. They usually come with the lesser expensive pressure washers.
Im not sure what you have, but for your job you would want to find a wand that has removable tips like i described.
Personally, i have a 3500psi gas powered pressure washer that i wash my vehicle with as well as cleaning the siding, cement, driveway, etc... It has multiple, removable tips to adjust the size of the spray from a jet tip (single stream) to a cleaner tip (narrow fan spray) to a wash tip (wide fan spray) and so on.
bg_2007Q7 (12-04-2022)
p3u
Auto Detailing Discussion
01-26-2009 09:22 AM
Det. Mickylaren
06-23-2004 05:06 PM
Andrew A4
27
02-02-2003 11:47 PM
RickM
09-10-2001 07:07 PM
