Directional front rotors on A4 B9? (non drilled/slotted)
I just replaced my front rotors (ferodo) and pads (TRW) on my 2016 A4 B9 TDI Quattro with fixed calipers (1LC). However after installation I noticed both rotors were the same, ie the internal vent vanes were looking at the same direction. Installed this way it looks like the left rotor has the correct orientation (vents facing rear looking from top) but the right one is the other way round so the vents are facing front, which should not be the case according to design I guess.
Checked the catalog again to make sure I did not made a mistake ordering and yes there is only one part number with required quantity of 2. No notes about directionality not on the box not on the catalog.
I will checked the old ones when I get back to the shop, those were the original ones from the factory. The right one showed signs of heat stress hence the rotor change despite good remaining thickness. I wonder if this is a result of the incorrect vane orientation on the rh rotor from the factory.
I've found very little information about this online, only some vw owners noticed the same on their stock golf R's and sets bought from VW directly.
How does your stock and replacement rotors look like?
That is how oem rotors are configured. There was a discussion thread on this in the past and, as I recall, someone presented testing information that indicated there was little or no difference in cooling based on the direction of the veins. There are some aftermarket rotors that are directional but I would imagine any benefit would only be evident under more extreme situations, such as on a track.
Distinct
13
09-18-2006 09:40 AM
huwla
04-23-2006 12:40 PM
ex-quattro PETE
12-06-2003 07:19 AM
ZoomS4
01-17-2002 05:09 AM
