Cleaning Forge Diverter Valves...
Does anyone know exactly what type (brand name) of high temperature grease to buy when cleaning forge diverter valves. Also where to buy this. I know Canadian Tire has some high temp greases but i am not sure which one to get.
TIA
Brian
TIA
Brian
Mobil 1 synth grease is what is used. Not sure where to get it here. >>
The Canadian Tire stuff is crap. i've used it....you'll need to lube your DV every 2 weeks. That stuff just doesn't last.
Super Lube
<center><img src="http://www.micro-tools.com/Merchant2/images/sl12cc.jpg"></center><p>Super Lube with Syncolon (PTFE) is a multi-purpose lubricant, safe to use on anything that slides, swivels, rolls or squeaks. It withstands temperatures within a range of -45 degrees to 450 degrees F. Superlube aerosol contains a solvent that evaporates upon exposure to air. The film of lubricant remaining forms a non-toxic, anti-corrosive shield that prevents rust and is imprevious to salt water. Super Lube is a synthetic, heavy duty lubricant that is compatible with most other lubricants.
SJGQ5
Q5/SQ5 MKI (8R) Discussion
08-11-2022 06:51 AM
gruvenparts.com
10-11-2016 04:47 AM
Audi A6 2003 allroad 2.7t for sale in AZ
blackjulia
09-27-2015 09:37 AM
