Did STFA, didn't see anything.....any good alignment shops in the GTA?
I've had the konigsport coilovers on for about a month now, and I'm getting ready to do the necessary alignment...anyone know of a good shop? I only found one post in the archives....there has to be more!
Lemme know guys....TIA
Later
Aman
Later
Aman
A regular Audi wheel alinement takes about 1.5 hours.....
At $80.00/hr, that's $120.00 plus taxes. Some dealers offer special deals on wheel alinements, so check in your area. This is of course for a standard wheel alinement as per Audi specs. If you have a lowered car with an aftermarket suspension, chances are it will be lower then the Audi sport suspension set up and it will most likely fall outside the Audi specs. That is not really a problem as long as you know, your camber will be more aggressive then the Audi specs. Just tell the guy to match every parameters on the alinement, Camber, toe and caster. It will be outside the factory specs but it will still be alined properly. Since the alinement is outside the specs it may take longer to properly aline it and thus more labor and more $$$.
