an error encountered while searching
Hi,
I would like to report the folloring error:
while searching for "windshield fluid", one of the returned hits was:
Alcohol lesson inside....
... alcohols are organic derivatives of H2O, with a hydrogen atom being replaced by a by an alkyl group (a hyrdrocarbon chain). The alcohol present in windshield washer fluid (and anitfreezes) is generally isopropyl alcohol (CH3CH2CH2OH for you budding chemists).... isopropyl alcohol is used as a rubbing ...
https://www.audiworld.com/forum/m/s4/msgs/125499.phtml 08/29/00, 888 bytes, database: s4
(on page 3 of the search results)
When I tried to open the page I got the following:
URL:
https://forums.audiworld.com/s4/msgs/125499.phtml
(page contents)
Error with SQL Query
select mid, tid, pid, aid, state, date, subject, flags, name, email, views, DATE_FORMAT(date, "%Y%m%d%H%i%s") as tstamp, UNIX_TIMESTAMP(date) as unixtime from f_messages-1 where tid = '' order by mid
Error #1064: You have an error in your SQL syntax near '-1 where tid = '' order by mid' at line 1
(end of page)
HTH,
Sebastian
URL:
(page contents)
(end of page)
HTH,
Sebastian
Able89
09-28-2015 05:35 PM
