Possible bug in edit feature?
This was in the A4 forum.<ul><li><a href="https://www.audiworld.com/forum/m.new/a4/msgs/324727.phtml">Link to the post.</a></li></ul>
Whenever you attempt to edit a post with a picture, the URL for the picture disappears from the "Optional Image URL" field and the software instead replaces the ENTIRE text of the posting with the HTML code to display the picture. If you then re-enter the image URL in the "Optional Image URL" box, the verification page will then display the picture twice, as the message text will then contain TWO copies of the HTML code to display the pictures.
Making this even worse, there is NO way to then post the change, because if you try to re-edit the message to correct things (e.g. to put the text the software just clobbered with the HTML code to show your picture or to delete the second copy of the picture), the software will re-display the message for verification and clobber the changes you just made...
