Feedback Need help with a Forums feature, noticed a broken link (or other site problem) or just have a general question - this is the spot
Problem with editing posts that contain certain HTML code
Old Apr 25, 2002 | 11:26 AM
Stoney's Avatar
Tech Guru
Default Problem with editing posts that contain certain HTML code
Hi,
Editing appears to break certain HTML code.
I posted a message last year with lots of links.
<A HREF="https://forums.audiworld.com/a6/msgs/95850.phtml">https://forums.audiworld.com/a6/msgs/95850.phtml</A>
I wanted to post a new message using some of the same content. So I visited that message, hit edit, and copied the info. I pasted it into a new message, and posted.
Unfortunately, the forum seems to replace some HTML characters with other codes, such that after editing, the codes no longer work. None of the Map links worked.
However, when I found my source on hard disk, and pasted that into the new message window, everything worked fine:
<A HREF="https://forums.audiworld.com/a6/msgs/146559.phtml">https://forums.audiworld.com/a6/msgs/146559.phtml</A>
I'm not sure if this means that a message with HTML code for certain types of links (such as maps) cannot be edited without breaking the links. In my case, it did. But perhaps something happened between last November 2001 (the original message) and today (April 25, 2002).
Old Apr 25, 2002 | 01:29 PM
Johannes Erdfelt's Avatar
Member
Default Ahh, I see what you mean
It's a bit too aggressive in converting the &amp; sign to it's SGML entity. It shouldn't be doing it for non text, like the URL for a link. I'll see about getting this fixed ASAP.
Old Apr 29, 2002 | 10:22 AM
Stoney's Avatar
Tech Guru
Default It converted an ampersand in the text portion of a link ...
... to "&amp;amp;" today. First, I posted a link as HTML, <A HREF="https://forums.audiworld.com/a6/msgs/147274.phtml">NorCal A6 Drive -- pictures by Randy Welch &amp; others</A>. Upon editing, it was converted.
FWIW...
Thanks!
Old May 12, 2002 | 09:42 PM
Member
This has been fixed FYI
IntheQ5
Q5/SQ5 MKI (8R) Discussion
38
Oct 21, 2024 10:43 PM
N'Syncro
33
Feb 16, 2020 03:12 PM
1stGOAT
45
Jan 13, 2018 07:36 PM
pcullen
Q7 MKII Discussion
Sep 2, 2015 12:54 PM
Powerofbabel
Sep 2, 2015 10:08 AM
