Fellow south floridians who live in heat and humidity, what synthetic oil do you suggest?
#22
According to this, 0-40 or 15-50 will work. 15-50 may be better for slow/heavy traffic conditions.
Mobil 1 Formula 0W-40 (European Car Formula)SAE 0W-40 Tri-Synthetic motor oil meets engine performance requirements of Porsche, Audi, Volkswagen, Mercedes, BMW, Volvo, & Saab. It offers outstanding protection in high-tech, high performance European engines by using a unique combination of three high performance synthetic fluids proven to outperform all conventional oils. Exceeds API Service SJ,SH/CF warranty requirements. Mercedes 229.1 approved. European ACEA A3/B3/B4-98 approved).
Mobil 1 Formula 15W-50SAE 15W-50 Tri-Synthetic motor oil is specially formulated for high performance engines & is used exclusively by Team Penske in all of their race cars. Outstanding protection for gasoline, diesel, & turbocharged engines. Pumps at -38F for fast oil supply to critical engine parts while providing superior sludge & wear protection under severe, short trip operation. Excellent cleanliness & wear protection in high temperature/hot running engines. Exceeds API Service SJ,SH/CF warranty requirements for Porsche, Audi, Volkswagen, Mercedes, BMW, Volvo. European ACEA A3/B3/B4-98 approved.
#23
To the horse's mouth...
Put in your vehicle information, and they will recommend the proper oil<ul><li><a href="http://www.mobil1.com/index.jsp">http://www.mobil1.com/index.jsp</a</li></ul>
#24
Soon as this thread started, I knew it was going to get Shane going for a long time....
I am surprise Ross has stayed out of this argument, he is usually very opinionated about motor oil and massage oil.
#25
*snicker*....I guess I just get a little annoyed when people
assume that an oil is to thin for a modern engine. Today's engines are an entirely different breed from those of 10 years ago. A lot of cars use to come with 20-50 as factory fill. More and more of today's high end cars are coming with 0-40, 5-30 etc.
I already said it once, and I'll say it again- 0-40, 5-30, and possibly 15-50 will do just fine as long as you use a decent brand and change it every 5k.
I think there is probably a lot of confusion out there about how a multi-vis oil actually works. Heck, I'm not entirely sure that I understand it.
I've seen a lot of good results with 0-40 (actual scientific analysis), and it seems to be working quite well in my car, so I see no reason to switch. I also trust Jorge's expertise (on cars anyways ;-) so if he says run 5-30 in your car, then run 5-30. The difference between the two is negligible in this climate.
#26
Here are the recs for my car. 0-40 comes up several times
Listed below are the oil viscosities that your vehicle manufacturer recommends for different temperature ranges, as well as the Mobil 1 motor oil that is suitable for your vehicle. You Chose The Following Vehicle:
Make: Volkswagen (edit)
Model: Jetta GLS (edit)
Year: 2002 (edit)
Engine: L4-1781cc 1.8L Turbo (AWP) (edit)
10W-30 5° F to 59° F
You can use Mobil 1® with SuperSyn<sup>TM</sup> 10W-30 with confidence. This viscosity is also available in Mobil Drive Clean Oil<sup>TM</sup> and Mobil Drive Clean Plus<sup>TM</sup> High Mileage formula.
15W-40 Above 5° F
Mobil does not carry that specific viscosity. While it is always wise to check with your vehicle's manufacturer, you can use Mobil 1® with SuperSyn<sup>TM</sup> 0W-40 or 15W-50 with confidence.
5W-30 All temps
You can use Mobil 1® with SuperSyn<sup>TM</sup> 5W-30 with confidence. This viscosity is also available in Mobil Drive Clean Oil<sup>TM</sup> and Mobil Drive Clean Plus<sup>TM</sup> - both the Newer Vehicle and High Mileage formulas.
5W-30 Below 59° F
5W-50 All temps
Mobil does not carry that specific viscosity. While it is always wise to check with your vehicle's manufacturer, you can use Mobil 1® with SuperSyn<sup>TM</sup> 0W-40 with confidence.
Year: 2002 (edit)
15W-40 Above 5° F
5W-30 All temps
5W-30 Below 59° F
5W-50 All temps
#27
So, should I stop using the Discount Auto Parts generic brand 15W20 oil?
Replacing filters gets expensive, so I just wash my filter out with soapy water, let dry, then reinstall. Works great for my shop vac filter! Is that bad?
ric714
03-23-2005 10:51 AM
nEw Audi A4 Driver
10-09-2004 01:59 AM
pipebender
08-17-2004 04:11 PM
LCP
Performance and Tuning
07-02-2001 03:06 PM
chillzatl
04-05-2001 06:45 AM
