TPMS Question
Old Dec 29, 2005 | 12:36 PM
TDI 4XMotion (Lee)'s Avatar
Junior Member
Default TPMS Question
Hello -
I recently had some tires put on and I think the installer accidentally broke the
TPMS sensor in at least 1 wheel.
VAGCOM tells me there is a communication failure, but I'm not sure which wheel is the problem.
Is there a way to decipher the fault code to know which wheel might be the problem?
Any other way to tell? Some scanner? I heard that the wheel sensors have a battery that eventually fails, but given that the failure happened right after my new shoes were installed...
I could bring it to the dealer, but thought I'd ask here first.
Old Dec 29, 2005 | 03:35 PM
Mr. Head's Avatar
Try emailing Andy at Ross-Tech. He should be able to tell you. andy@ross-tech.com
Old Dec 29, 2005 | 05:14 PM
Junior Member
Default Great Idea...posting to VAGCOM forum at VWVortex first...
<ul><li><a href="http://forums.vwvortex.com/zerothread?id=2365384">http://forums.vwvortex.com/zerothread?id=2365384</a</li></ul>
Old Dec 29, 2005 | 05:15 PM
Mr. Head's Avatar
Default There is also a vagcom forum here on audiworld as well..
but he responds very quckly by email. As long as you are an actual Ross-tech customer, he is happy to help you by email..
Shoot, he actually helped me to get a dyno plot working right when i sent him the data...
Old Dec 30, 2005 | 05:33 AM
Junior Member
Default Got an answer on the Touareg forum...posting here for posterity
"Go in with the VAG COM and take measurements (controller 65 if I remember correctly). Channels 01, 04, 07, and 10 show the pressure values. A bad sensor or receiver (much less likely) will reveal itself. To figure out if it's the sensor or receiver, swap the wheel."
choptt
Audi allroad
Nov 10, 2008 12:33 PM
islingtonaudi
Jun 19, 2006 11:10 AM
Audi888
Apr 4, 2002 06:44 PM
Norcalguy
Dec 10, 2001 05:05 PM
