sluggish 2000 S4
Old 03-08-2007, 10:18 AM
New Member
jpfs4's Avatar
Default sluggish 2000 S4
hey guys,
I was just out driving and decided to push it from a standstill. to my surpirse, i didn't have the power i'm accustomed to after the 4K RPM mark...for those who drive this car, the power that sits you back in your seat.
prior to this, I haven't been hearing anything unusual from the turbos. does this sound like a bad turbo or perhaps loss of pressure due to a bad hose/wastegate or something?
car has been well taken care of for 86K miles.
ideas?
Old 03-10-2007, 07:50 PM
New Member
DasTrufel's Avatar
Default Re: sluggish 2000 S4
I would first check the intake boot on the throttle boby for tearing on the bottom side. next check for any boost hoses loose or torn. If everything is ok, you will need to take to someone to look at some measuring value blocks in the ECM while driving
Old 05-22-2007, 01:39 AM
New Member
NocturnalRacer's Avatar
you might be getting some boost leak, so maybe a hose got loose or something
Old 10-06-2007, 11:48 AM
LaserRedB5S4's Avatar
really simple, get someone with a VAG tool, you probably through a code and thereby went into limp mode, don't know anyone? pull the ECU fuse when the car is cold, I believe it's number 27, by pulling it you will reset the ECU and the code will be gone. Chances are the code will reapear eventually but atleast you know it's that and not something else.
slowguy
9
02-12-2013 04:18 PM
jpfs4
03-08-2007 04:43 PM
Gray_TT_2003
12-24-2004 12:44 PM
M3KILR
9
09-30-2003 06:19 PM
maxma
9
12-13-2002 07:11 AM
Quick Reply: sluggish 2000 S4
