As in direct swap? There are none. Only the stock ADZ code 016
You will need to change flywheels, clutch, clutch slave, mounts, shifters and possibly axles to make an 01E go in a '91 200q. You would also need to eliminate or modify the PROCON 10 brackets and/or cables, as I believe that the 01E brackets are in a different position than the 016 PROCON stuff. NOT an easy swap by any means.
Not worth it IMO. I would likely be cheaper to sell the car and buy an S4/S6 that someone already converted. Six speeds are bolt-ins with S4/S6s.
FWIW, the only 200q that I have ever heard of with a six speed was a race car that MTM built.
