Engine problems
Old Jan 3, 2006 | 07:47 AM
quattro100's Avatar
Default Engine problems
I had problems with my car this morning. The car started fine and drove fine for about 1/4 mile. Then the engine started to sputter and die. It did this like 20 times as I tried getting back home. It always started up fine but would begin sputtering and not accept the gas pedal and then die. Any ideas. My guess is a vacuum line problem.
Old Jan 4, 2006 | 08:22 AM
Audilard's Avatar
Default Sounds fuel related...
Naturally, you should pull codes. Then check the fuel pump.
Old Feb 14, 2006 | 02:46 PM
quattro100's Avatar
Default Re: Engine problems
Turns out the problem is with the O2 sensor getting wet and causing problems. If I disconnect the plug, the car will run.
SoCalJ
12
May 20, 2014 11:29 PM
PoWeReD-By-AuDi
Q5/SQ5 MKI (8R) Discussion
Oct 22, 2011 01:38 PM
Janus
Jul 17, 2004 12:51 PM
Arson
Apr 28, 2004 09:57 AM
Liam in Montreal
Apr 4, 2001 11:42 AM
