Engine problems continued...
Old Apr 4, 2001 | 11:07 AM
Liam in Montreal's Avatar
Elder Member
Default Engine problems continued...
Yesterday after work I went to the car and it started up fine (in the morning I had some problems with the engine dying/coming back to life continously).
I suspected condensation in the fuel tank and/or fuel filter.
Anyway the car started up fine, worked fine all night, worked fine this morning, but at lunch time it started acting up in the same way.
at idle, check-engine light turns on, rpms fall to 0 (or almost 0), check light turns off, rpms rise up to 1500-2000. If I give it gas I hear air go in, the "vroom" of the engine but rpms never go up....
Could this be ECU related? still water in my gas?... any feedback appreciated.
thanks,
Liam
Old Apr 4, 2001 | 11:22 AM
Bobby Kinstle's Avatar
AudiWorld Uber User
25 Year Member
That's what mines doing today (see below)
Old Apr 4, 2001 | 11:42 AM
Elder Member
Default Thanks but mine isn't ok above any rpm. your problem sounds like
you are running on less cylinders. (at low rpms the engine has more problems running, but at high rpms everything is ok). maybe a spark plug problem. check those first.
But Ron_c suggested checking the coil-pack, I'll do that.
best of luck,
Liam
Panelhead
15
Aug 21, 2014 04:53 AM
Vlado
Q7 MK 1 Discussion
Mar 16, 2012 09:19 PM
quattro100
Inline-5 Discussion
Feb 14, 2006 02:46 PM
'Bahn Burner
Mar 20, 2002 03:01 PM
jackr
Jul 27, 1999 06:53 AM
