help
explains why i have my bddies 7A and he put a V6 twin turbo in his CQ
When accelerating does it feel like the brakes are on? That's a typical feeling with a vacuum leak. A little stumble every so often?
Since it does come on at higher rev's the would usually indicate sufficient fuel. I'd also look at the air filter for any big flow restiction, if running rich by chance. With the metering plate exposed reach in there and see how easily it moves up and down. A sticky plate will cause it to be sluggish but also it generally would want to make it stall depending on how sticky it was.
The NG should come on around 2200 or so but doesn't have a whole lot of HP for a heavy car.
Report back on what you find.
