Question about NF engine code...
Old Nov 8, 2006 | 06:52 AM
sic_fast's Avatar
Default Question about NF engine code...
I know that the NF came in the 5000 86-88. Then it came later in the 100 with a different two piece IM. My question is are the oil squirters present in both blocks, or is the block in the 100 actually an NG block? I'm trying to source a long NF Block for a 4KQ but I'm not sure where to look.
Old Nov 13, 2006 | 08:04 PM
ddg=shinebox racing's Avatar
Default to answer your questions: yes and yes....
they both have squirters and the NG came in the "100" and "90"
the link in my sig has some specs and info on both engines...
<img src="http://pictureposter.audiworld.com/41804/imag0026.1.jpg">
Old Nov 21, 2006 | 12:59 PM
Dwight V.'s Avatar
Member
Default Tidbit about the squirters
Plan on replacing them unless the engine is uber-clean inside. My donor had several coked shut. They aren't cheap either.
Old Nov 24, 2006 | 04:00 PM
sic_fast's Avatar
Default Are they still easily available?
I found an NF short block for 365.00 out of a 5000. Seems reasonable to me vs. 650.00 for a 2.5L Eurovan (short).
Old Nov 25, 2006 | 12:13 PM
cuatrokoop's Avatar
Default You don't have to replace them...
All they are is a spring-loaded ball-style check valve. Clean them up with carb cleaner and make sure the ball moves freely if you can.
Gray_TT_2003
May 19, 2005 01:00 AM
Yukonr
Jan 7, 2005 04:40 PM
CorradoZilla
Jan 28, 2004 03:04 PM
Allnighter
Audi 100 / A6 (C4 Platform)
Jan 15, 2004 08:02 AM
Casablanca Avant
Jun 17, 2003 09:46 AM
