Wheres the Cold Start valve on a CQ I5?
CIS or EFI?
If your talking a 20V coupe. I thought those were EFI and has an ISV but there is automatic cold start enrichement from the ECU. If its a 10V CIS, then the CSV is gonna be over by the Fuel distributer next to the intake manifold. There'll be a stainles steel braided fuel line going to it. Easy to spot cause its the only thing other than the 5 fuel injectors which is getting a fuel line and it connects to the intake manifold.
hrrrmmm if thats a NG motor its here...
this is on the left side of motor, between the manifold and the airbox..kinda what fusilier said..follow the 6th fueline down to it..cant miss it..its the only blue thing down there.
<img src="http://pictureposter.audiworld.com/78580/luke_083.jpg">
Thats probably your ISV
It regulates airflow into your motor and bypasses the Throttle body at idle. The MAF reads a higher air flow and correspondingly adds fuel. Reduce the ISV bypass and the idle should go down. Also chk your throttle body and see if there is an adjusting screw.
7A....So it's EFI, and there are two slight variations on it's ISV theme...
Either way, the ISV on the 7A is located on the airbox (bolted to it). My early car was at least bolted to the airbox....
VonK :: Retired
13
02-03-2003 06:38 PM
Type44Q
10-15-2002 07:16 PM
