1990 audi 80 coolant temperature guage problem
Guage, sender, or wiring problem.
Normally its usually the sender, or a bad wire.
The guage is a rare item to go bad.
The sender can be ohmed with a voltmeter to test if its bad. As can the wires.
Check to make sure its connected.
Yea, I had to replace the multifunction sensor on my CQ & 90....
It could be the sensor that screws into the block up front where the coolant hose goes in. These seem to go bad after 100K or so.
Re: Guage, sender, or wiring problem.
No, that "item" is the thermoswitch for your radiator fan. If your rad. fan quits...now you know where to look.
I know where you need to look to fix the temp guage in the 5-cyl...but your car has the 4-cyl, correct?? I have no idea on the 4-cyl!!
Sorry, I couldn't offer any more help!!
Andrew
90 80q
91 90
95 90q
Andrew
90 80q
91 90
95 90q
Re: sender local
<center><img src="http://www.ibiblio.org/tkan/audi/auti1/engine.jpg"></center><p>In the picture, just aft of the #3 spark plug, the neck coming out of the head, with the long rad hose, has 2 senders in it. 1 on top 1 on bottom. The one on top is the guage sender. 1 on bottom is temp sensor for ECU.
Re: Coolant temperature sensor
I have a 1990 Audi 100, and I've been told that it's the coolant temperature sensor that's bad on mine. Is that the one you are refering to?
If so, where can I buy it inexpensively ?
Please kindly let me know. Thank you.
